Software has updated and zooms out when making alterations
wingspanner
wingspanner
Every zoom.pngtime i amend my image it zooms out (as show in image) I can zoom back in but then if i rotate the image it zooms out again! I was working on the software and it did an update and now its
ryan.bales
Autodesk Support
Autodesk Support
Wow that is zoomed out VERY far! I'm not seeing that on my sketches though, can you share your model?
It might be worthwhile to do a Compute All as well.
Ryan Bales
Fusion 360 Product Support
HughesTooling
Do you get the same zoom problem in a new design or is it just this design? If it's just the design in the image you attached can you share it here? Just export as a f3d file and attach.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Also looks like you have a message on the toolbar, is it an error message.
Mark
Mark Hughes
wingspanner
thanks mark it was only in this design. I have redrawn it and its ok now.
