- Mute
- Permalink
- Report
This may be caused by the same problem that is covered in another post here about locking up on changing the name of a drawing, if so please let me know and I will mark the thread solved.
Below is an image of the screen. In this state nothing is selectable, neither does right-click bring up a menu, I can't even use the "X" to close the whole application.
To get here I copied some text from a notepad doc into the text box, then I clicked and dragged over the "2." of the "2.5" in the height field of the text properties box and then hit the delete key.
If I right click on the application in the windows taskbar and select close, sometimes it asks me if I want to save the document but then it doesn't let me interact with any buttons to say yes, sometimes I get this:
To get rid of that, I have to manually kill the process in taskmanager.
I've tried to run the service utility to get my system info but for some reason when I go to add / remove programs and select modify, it flashes a box on the screen for a second, but otherwise does nothing. Holding CONTROL + SHIFT whilst opening fusion doesn't open it either.
I have attached the model that this drawing is of as the drawing itself was lost when I force closed fusion, however, this has certainly not been limited to this model.
