Snapping to the center of a projected circle.
When I project a, sketch, (circle), onto the surface of an inserted design, the subsequent projection doesn't seem to allow me to snap to the center of that circle. The surface is on an inserted design, but the projection isn't, so shouldn't it be able to find the center of the projection?
Also, when I use press pull to extrude the sketch, (circle), into a body on that inserted surface, it allows me to use the "Join" parameter. But if the design is inserted, it adds a new body to the root of the document rather than any other body. I suppose this could just be a known caveat, but is it possible for the press pull operation to know it's on an inserted surface so it can dim the "Join" option?
