Snapping to the center of a projected circle.
hclmed
hclmed
When I project a, sketch, (circle), onto the surface of an inserted design, the subsequent projection doesn't seem to allow me to snap to the center of that circle. The surface is on an inserted design, but the projection isn't, so shouldn't it be able to find the center of the projection?
Also, when I use press pull to extrude the sketch, (circle), into a body on that inserted surface, it allows me to use the "Join" parameter. But if the design is inserted, it adds a new body to the root of the document rather than any other body. I suppose this could just be a known caveat, but is it possible for the press pull operation to know it's on an inserted surface so it can dim the "Join" option?
jhackney1972
Please attach the problem model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
