Slow response to 'S' search shortcut.
I will often use the 'Search' shortcut in my workflow to call commands. I'm having an issue where the search bar lags to pop up (~5 seconds) and another couple of seconds to process anything I type. Using the Ribbon to call commands seems to be running as normal, and overall Fusion is running at about normal 'speed'. I've cleared the cache data, restarted (program and system) and made sure I'm up to date on drivers and Fusion.
I realize this might be an isolated case but wondering if it's a known issue or if there's anything I can check on my side to diagnose.
Cheers!
  • UI
vinivaghani
clear your catch history and clear your all online work/files
