slow performance when driving circles or lines
bombolo
Message 1 of 13
bombolo
Very slow when I edit a track and draw a circle or a line. Problems after last Fusion update. Use HP PC with AMD 4C 2.40 Ghz - 16 RAM
Replies (12)
Message 2 of 13
James.Youmatz
Autodesk Support
Autodesk Support
Hi @bombolo ,
Can you create a screencast of the performance issue. Also - is this only for one certain file/sketch, or is it happening on brand new designs.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 13
bombolo
Message 4 of 13
HughesTooling
What graphics card do you have? Can you attach a copy of your graphics diagnostics, try enabling limit effects on the graphics diagnostics dialog.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 5 of 13
bombolo
[GPU Information]
GPU Device: AMD Radeon(TM) R5 Graphics
GPU RAM: 512 MB
GPU Driver API: DirectX 9.0
GPU Driver Version: 23.20.808.1536
GPU Driver Date: 03/30/2019
[Graphics Effects Settings]
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: Off
Selection Display Style: Simple
Transparency Effect: Better Performance
[Limit effects to optimize performance]
On
Message 6 of 13
James.Youmatz
Autodesk Support
Autodesk Support
Hi @bombolo ,
That is a very weak graphics card, and I believe it is AMD's integrated solution. Does your machine have dual graphics card. It is hard to say if what we are seeing is related, but as @HughesTooling suggested - it may be.
Also, how much RAM does your computer have available? It looks almost as if it is taking a long time to compute. Have you used Fusion a lot in the past?
James Youmatz
Message 7 of 13
bombolo
16ram. I use Fusion every day. I have been using this PC for 1 month because my beloved Mac has stopped working 🙂
Message 8 of 13
HughesTooling
You didn't really answer the question if Fusion has worked OK on your PC. Don't suppose you've deleted all active projects like the people in this thread. Might be worth exporting and uploading your diagnostics log as well.
Mark
Mark Hughes
Message 9 of 13
bombolo
On this PC I worked without problems. I don't know what diagnostic log means. I'm sorry.
Message 10 of 13
bombolo
diagnostic log
Message 11 of 13
bombolo
Fixed problem by buying a new Mac. Abandoning windows forever...
Message 12 of 13
HughesTooling
Not a Windows problem just a corrupt install, could happen with any computer\os. Don't know where support has gone, doesn't seem to be a lot of help at the moment!
Mark
Mark Hughes
Message 13 of 13
James.Youmatz
Autodesk Support
Autodesk Support
Hi @bombolo ,
I am sorry for the delay - I missed the notifications last week. As @HughesTooling mentions, it may just be related to the installation/or perhaps even a bug with a certain driver and how it interacts with Fusion sketching. Let me know if you want to attack this again on your Windows machine.
James Youmatz
