Slow performance in 2D sketch
alis990
Message 1 of 12
alis990
After last update, I'm encountering low performance only when editing sketch in nested components.
Even when I create new project, then empty component, then nest inside another one in which i make sketch.
That was never an issue.
I'm still running Win7, so it can be partially that.
I changed graphics driver to OpenGL, and it helped, but it's not as smooth as before.
Replies (11)
Message 2 of 12
TheCADWhisperer
Is Fusion 360 supported on Win 7?
Can you Attach a *.f3d file here that exhibits this behavior?
Message 3 of 12
alis990
Officially no.
As said earlier, even new projects have that issue.
Message 4 of 12
TheCADWhisperer
I didn't see anything obviously wrong - in fact, it looked pretty good.
I suspect the issue is with the Win 7 OS or maybe graphics card/driver.
Message 5 of 12
alis990
Graphic card driver is from 27 II, so newest. I updated it before posting.
Message 6 of 12
I have same issue. When sketch shown i have a very low performance. When i hide all sketches all go work very fast. With many elements on sketch (10-20 primitives) it so slow so i cant set dimentions or move dots or lines. VERY slow.
Windows 8.1 i not change anything for a long time and have this low performance issue just after last Fusion 360 update.
Message 7 of 12
TheCADWhisperer
Windows 8.1 ...
@Anonymous
This sounds like a completely different problem.
Message 8 of 12
Okay. I also record video: https://www.youtube.com/watch?v=xeGc8eCMvtM
Message 9 of 12
TheCADWhisperer
First thing I would do is simplify your sketches.
As part of that simplification - I would fully define the sketches.
On the left is your first sketch - on the right is my simplified sketch.
Message 10 of 12
But this not answer why showing sketch make editing so slow. First sketch is not so much but second one i cant edit well while it so slow. When i try set dismention i need wait with mouse down button for a few mins! This is abnormal and not exists before.
Message 11 of 12
HughesTooling
I had some graphics performance problems after the last update and found I need to change the graphics driver to OpenGL.
Mark Hughes
Owner, Hughes Tooling
Message 12 of 12
Thank you! I test all 3 options and All DirectX work very slow with sketches but Open GL work very fast.
