Sketches now uneditable after update
maryrm70
maryrm70
Community Visitor
Community Visitor
After the most recent update, I am suddenly unable to edit a sketch while in sketch mode. For example, I created a center rectangle and entered dimensions, however while still in sketch mode I cannot alter those dimensions, I cannot use "fillet", etc. It's like while still in sketch mode it's locking down my selections before I even hit finish sketch. Something is seriously wrong and it must be the update as I was able to function normally just yesterday!
-KyleWilliams-
This sounds like a selection filter issue to me.
Are you able to check what your filters are set and ensure that they include at minimum the sketch options?
Kyle Williams
Senior Customer Advocacy Manager - Design and Documentation
Ontario, Canada
Become an Autodesk Fusion Insider
TheCADWhisperer
@maryrm70
grant.lumsden
Are you trying to do this in a section view? (Analysis On)
I can sketch OK in a section, but can't then select any of the profiles to do a revolve or whatever.
I have to turn Analysis off, and then I can select the profile.
This is a new feature since the 09/09 Update...
pkomatlapalli
Hi @maryrm70 ,
Did you get the chance to look into KyleWilliams, TheCADWhisperer and Grant.lumsden follow-up questions or still you need help from the community,
If you were able to resolve it, could you please let us know what solution or workaround worked for you?
Sharing your experience would be greatly appreciated, as it may help other community members who encounter the same issue in the future.
Thank you for your time!
Pavan Kumar | Community Manager
Closed-Loop-Bot
Thanks for bringing this to our attention. We're investigating the issue, and you can reference ticket FUS-274836 when communicating with Autodesk to find out more. Once the status of this will change, there will be a follow-up forum post made.
