Sketch with offset line impossible to fully constrain
cooperAL5P5
Message 1 of 8
cooperAL5P5
Little bug report, can't seem to fully constrain this sketch. I′ve had similar problems with sketches that use offset lines in the past.
(view in My Videos)
Replies (7)
Message 2 of 8
davebYYPCU
You can't add dimensions to any offset article.  You can add them to the original articles.
Dimension inside vertical height - works.
Might help....
Message 3 of 8
cooperAL5P5
Hmm sorry for my post in that case. But I'm confused, because as shown in the video and still now, I can't seem to constrain that inner vertical height. The original lines are the inner ones. If I click on one of those inner vertical lines and try to dimension it, I get the "over-constrain" error.
Message 4 of 8
davebYYPCU
I selected bottom and top line.
I also tried making the left vertical equal to the 3 inch line, both worked here.
Might help….
Message 5 of 8
cooperAL5P5
Ah ok, I see that works. I think this is still a mini bug report, seems like just clicking one of the vertical inner lines and adding a dimension should work. But I'm seeing that workaround, works great, thanks!
Message 6 of 8
davebYYPCU
I agree with you, selecting the left vertical line to dimension it, should not generate over constrained errors.
@Phil.E can you get this into the sketch bucket?
Might help...
Message 7 of 8
Phil.E
Thanks, I'll ask the sketch developers to take a look.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 8 of 8
sameer_babarNJS6C
@cooperAL5P5  Thanks for reporting this issue to us.
We can reproduce this issue at our end with the part provided by you .
We have created a ticket (FUS-159507) for it  & we are looking for the solution .
Sameer Babar.
Autodesk Fusion Team
