Loft not following rails how I'm intending
cooperAL5P5
cooperAL5P5
I'm trying to make a loft that wraps around the edges of a body as it progresses:
I made rails that perfectly follow the curve of the body, but the loft surface still ends up clipping through it a bit. What am I getting wrong?
Design is attached. Thanks!
TrippyLighting
You are only having control over the shape of the loft where you have rails, but that isn't enough.
You should loft this with individual surfaces:
Model is attached.
Little tip. For the benefit of those who help here on the forum, please remove non-essential linked components before uploading the design. That makes it a quicker process for us to open files 😉
cooperAL5P5
Aha, I see how it works now. Thanks so much!
Good note about the non-essential linked components, will do in the future 👍
