Sketch Problem: Reference Existing Feature in new Dimension
Amyoqzy
Message 1 of 9
Amyoqzy
The following Sketch is driven by the tool measurements (114mm):
Now I am about to add the locations for the screw holes. I would like to simply divide the outer dimension by 3.
Fusion 360 did all calculations for the outer dimension, but it seems I am unable to reference it.
So, how can I add the correct dimension for 1/3 of the outer length of this part?
I am aware I could do it ridiculous complicated like this:
- Manually referencing all existing dimensions and create a large calculation.
Replies (8)
Message 2 of 9
TheCADWhisperer
Why is all of your geometry blue?
Where is the Origin?
Oops, I just read your problem description again.  I got hung up on the 114 dim.
You will need a mature product like Autodesk Inventor Professional for this functionality.
In Inventor, you add the reference dimension and then make your dimension a function of the reference.
Not possible in current release of Fusion 360.
Message 3 of 9
Amyoqzy
It would be unfortunate if there is no way to solve this in Fusion 360. Something like this is IMO basic CAD functionality.
If Fusion360 had no parametric system, I would totally understand I had to calculate dimensions manually. But if there is already a line with a calculated length, but I cannot reference this dimension... it is just ridiculous. 😄
Message 4 of 9
TheCADWhisperer
@Amyoqzy wrote:
... but I cannot reference this dimension... it is just ridiculous. 😄
Yep, especially when this issue was solved longer ago than I can remember (I'm guessing more than 10 years ago).
Design Differently!  🤔
Message 5 of 9
jhackney1972
As has been mentioned, Fusion 360 cannot pick up a reference dimension as a parameter.  You can design this problem a different way and I believe get what you want.  The only thing you did not specify is the segment between the end of your block and the tool measure, I am specifying that as a parameter, which can be changed.  I am also making the assumption you will be creating a solid from your sketch because I use that value in my parameter table.
John Hackney, Retired
Message 6 of 9
jhackney1972
Forgot to attach the model used in the Screencast.
Message 7 of 9
g-andresen
just do it this way and create a point for your drilling if needed
günther
Message 8 of 9
Amyoqzy
This is an interesting approach. Yet, for me it feels horribly wrong, to have to creatively work around something which just should be possible. 😄
Message 9 of 9
Amyoqzy
günther
This is what I actually did in the end. But, I feel stupid if I have to repeat a calculation Fusion360 already did. It also adds a possible source of error to the design: If you already added the formula, but later add an additional feature, you have to update this formula - otherwise, the dimension will not match anymore.
Also, if you e.g. need 5 or mode dimensions based on this length - it is way simpler to write five times "ref / 5" instead of "(long formula with many references) / 5". 😄
