Sketch palette not showing
lars_kooijman
Message 1 of 24
lars_kooijman
I have noticed a bug where the sketch palette did not show when drawing lines, rectangles etc...
Now I found out how to reproduce it.
When I have 2 files open and are both in an active sketch, the sketch palette only shows in the sketch started last.
After I finish one of the sketches the sketch palette shows in the other opened file window.
Replies (23)
Message 2 of 24
g-andresen
did you try "Reset to default layout"?
günther
Message 3 of 24
sameer_babarNJS6C
Hello,@lars_kooijman
Thank you for posting this issue.
This is known issue and we have already fixed it, currently it is going through validation process.
Very  soon we will resolve this issue.
Sameer Babar.
Autodesk Fusion 360 Team.
Message 4 of 24
teknikHCEMT
Observer
Observer
I have same proble, sketch palette is not showing.
I tried Ctrl + Alr +R with no effect on showing the palette.
I reinstalled the Fusion 360 and that did not help.
Message 5 of 24
hpollina
Community Visitor
Community Visitor
I am also having the same issue 😞
Message 6 of 24
sameer_babarNJS6C
Hello , @teknikHCEMT @hpollina ,
Can you please try after upgrading Fusion to the latest version as we have already fixed this issue in current production version(2.0.17954).
Let us know if you still face this issue.
Sameer Babar.
Message 7 of 24
vladimir_turin
Observer
Observer
Having the same issue. Have  Fusion version 2.0.18441 x86_64, running on Windows 10 Pro 22H2 (19045.3930).
Reset to default layout did not help.
Message 8 of 24
tosch_contact
Same issue with 2.0.18441 x86_64  - "Reset to Default Layout" does not help
Message 9 of 24
mek985
This is not fixed. Using Fusion 2.0.18950 arm64 [Native]
I'm new to Fusion, and I'm switching from my Fusion space to my video tutorial space a lot. Browser and Sketch palette flicker, then disappear entirely each time I switch back to Fusion. At least I can use the browser toggle key trigger for that, but the Sketch palette is harder.
I've worked around it temporarily by leaving sketch mode, clicking home at the cube, then reentering sketch mode and activating a drawing plane. Not sure how this has hung on for so long (through several releases). Wish my first post hadn't turned out to be such a rant.
Message 10 of 24
adam3RC8W
I'm using version 2.0.18961 x86_64 and the sketch palette still disappears sometimes. The only way Fusion was still usable is because I knew I could change line type with the 'X' key.
But now I've found another workaround. While editing a sketch in your project, create a "New Design", click on "Create Sketch" in the new design and the sketch palette shows up. Now if you just close the new design tab, the sketch palette is still showing in the project you were previously working on.
Message 11 of 24
h_l_c
Community Visitor
Community Visitor
THANK YOU SO MUCH FOR THIS!!! I am still having this issue and my Fusion JUST updated to the latest version 2 nights ago. Neither reset layer nor CTRL+ALT+R was working. I was losing my mind! This workaround is the only thing that's consistently worked. Very much appreciated!
Message 12 of 24
jasonEGE5A
Observer
Observer
I can confirm this is still happening as of 2.0.21550 arm64. The only thing that fixed is for me was the above workaround, to open a document and start a sketch. Then it's active again in all windows. 😞 not great.
Message 13 of 24
jasonEGE5A
Observer
Observer
This is not fixed as of 2.0.21550 arm64. I just confirmed the below described workaround fixes it, but nothing else. Not resetting the workspace.
Message 14 of 24
mek985
I can sympathize, although I'm not using Fusion any longer because, as an individual who is retired from an educational institution, I'm not pleased with Fusion's purchase policy for educational retirees. The policy is that there is no discount for edu retirees regardless of the length of the edu affiliation.
Message 15 of 24
gwagnerJXG2J
Thank you for the New Design tip to get the sketch palette back.
At least there is a way to do it.
Can confirm that disappearing sketch palette still happens in
Fusion 2603.1.11 x86_64
Seems fine for a while after starting a design ... after going on for a while it just decides at some point not to show up any more when doing "edit sketch".
BR,
-- Glenn
Message 16 of 24
fkKNLVL
I'm having this issue right now, the sketch palette is not showing up when im in edit sketch mode, and this is on the latest update!
Fusion 2604.0.316 x86_64
Active Plan: Subscription
Windows 11 Pro 24H2 (26100.6584)
Message 17 of 24
shiron84596
Community Visitor
Community Visitor
SolidWorks veteran here. I am facing this issue right now. I am using the latest version: 2605.1.52 x86_64 | Windows 11 Enterprise 24H2 (26100.7462).
I had to use Fusion for a new project due to licensing and had high hopes. I am surprised Autodesk can't simply fix this bug, despite reports going back a few years now. The official help channels don't seem to have a clue. However, the trick of jumping between a new design and the current design works, though it is frustrating.
Message 18 of 24
dehullu_robin
Community Visitor
Community Visitor
Still not fixed in 2606.1.22 x86_64 | Windows 11 Home 25H2 (26200.7462). Such a crucial feature should not be broken for over two years.
Thank you, Adam, for the workaround.
Message 19 of 24
tannippm
Community Visitor
Community Visitor
thankyou for this
Message 20 of 24
washleyMB2KW
Observer
Observer
Thank you very much. Your solution is (sadly) still useful 2 years later. Well done Autodesk.
