Sketch drop down menu missing
When I click the dropdown menu under the sketch Icon nothing happens now. This is new it's worked before. Very frustrating. All other menus work. I need sketch..
ryan.bales
Autodesk Support
Autodesk Support
Hi @Anonymous,
I would start with resetting the tool bar. Right click in the toolbar and select reset toolbar customizations. If that does not work you can try resetting Fusions default layout under File>view>reset to default layout.
I'm assuming this worked before?
Ryan Bales
Fusion 360 Product Support
Actually I figured it out. It was my screen resolution. If the drop down
menu doesn't fit on the screen it won't open. I moved the toolbar up a
little and it opens fine. Down a little and no open.
ryan.bales
Autodesk Support
Autodesk Support
Hmm, are you using a 4k or high resolution display?
If so i'd recommend disabling display scaling as seen here.
Ryan Bales
george_pavlou
Observer
Observer
Changing the "scale and layout" from 125% to 100% fixed this problem
