Sketch Dimension issues following 6.20 update
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am currently working on a project with many fairly complex sketches. Following yesterdays update, the larger ones will not allow me to dimension any additional lines.
As an example. I have a line which is the outer edge of the sketch(constrained), I draw a line parallel to that (which works just fine) then I go to dimension the distance between the two and I am told it is over constrained. The newly drawn line is blue as it should be and the one I am attempting to dimension off of is black and constrained.
I am now experiencing this problem in several other flies.
I figured to remedy this I would just jam out a new sketch in a new file hoping this would be resolved so I could continue with my other work... I have reached a less developed point that in the previous sketches(which are now useless) and I am again experiencing the same "over constrained" issue.
Is anyone else experiencing this? did I forget how to use fusion while I was at lunch yesterday? Is there a limit to how many constraints can be used in one sketch?
I am sorry I don't have the file linked, this is my first time posting and I am unfamiliar with the process.
Thanks!
