Sketch Dimension alignment selection
josh.sapp
Message 1 of 9
josh.sapp
Where has the option to constrain sketch dimensions to the; vertical, horizontal, or aligned gone to? It used to be a RMB click while dimensioning in the sketch. As seen in the following video at 1:28.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-27529A4E-48A5-470C-AA5A-6D438EBFE6A9
Replies (8)
Message 2 of 9
TheCADWhisperer
@josh.sapp
Are you in 2D sketch or are you really in 3D sketch?
Message 3 of 9
g-andresen
it´s still like that.
günther
Message 4 of 9
HughesTooling
Still works for me.
Mark Hughes
Owner, Hughes Tooling
Message 5 of 9
josh.sapp
I'm in 2D sketch. I'll share a file later. I'm not at the computer at the
moment.
Message 6 of 9
HughesTooling
One thing to note is you need to have made a selection (line or 2 points) first.
Mark
Mark Hughes
Message 7 of 9
josh.sapp
Yes sir. I was in the middle of dimensioning a sketched line. Hit the RMB
expecting to see the menu as it had always been there. When there was no
menu to constrain the dimension.
Message 8 of 9
josh.sapp
Thank you everyone.
I opened another file and every thing was fine. It seems to be just this particular model. attached is a screen shot of the issue along with the design file.
Message 9 of 9
josh.sapp
Sorry All.
It was reading the line as horizontal and didn't need to do anything else.
