Since last update I can´t open files after starting fusion
uphone
uphone
Hi there,
I have installed the last update a few day ago and since then always when I start fusion and want to open a construction I become the error "can´t open file". When I repair Fusion with the service tool it´s ok and I can open and work with my files. But it is a little bit annoying to do this every time I want to work on my constructions. Is there a solution?
RajkumarIlanchelian
@uphone The logs shows that you are on version Version : 2.0.18220 and that the design is saved in 2.0.19994. Do you work on multiple machines or do you collaborate with others that edit the same files?
On the machine that you are having this issue:
1. Logout of Fusion/Close Fusion
2. Restart machine
3. Download the Fusion installer again
4. Delete the Fusion shortcut you use to launch Fusion
5. Install Fusion
Let us know if the above solves your issue.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
