Simulations stucks at 1%
id00859520
Message 1 of 34
id00859520
For any simulation you do, even in the case of only a linear load on a bar it remains loaded at 1% and does not advance even if you leave it for a long time.
Replies (33)
Message 21 of 34
osa065
Still the same, the simulations wont run.
Message 22 of 34
henderh
Thank you @osa065 for checking again. We've encountered a new technical difficulty where clearing queues isn't taking effect for some accounts. We're actively pursuing a solution, and will update this thread accordingly.
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
Message 23 of 34
zcem1
Observer
Observer
I kindly request an update regarding the issue I am currently facing. Given my workload of assignments, I would greatly appreciate any expedited assistance you can provide in resolving this matter. Thanks.
Message 24 of 34
henderh
Hi @osa065@zcem1@albertogutmar, and @antonkunipatz,
We've untangled the wires for you accounts. Please let us know if solving is working now or not.
Apologies for the delay(s).
Hugh Henderson
Message 25 of 34
osa065
Thank you i have just run a simulation and its working. I appreciate your help!
Message 26 of 34
henderh
Awesome news @osa065!
Thank you for letting us know you're back up and running.
Hugh Henderson
Message 27 of 34
zcem1
Observer
Observer
Its working now. Really appreciate it @henderh.
Message 28 of 34
henderh
No problem @zcem1. Thank you for confirming & your patience!
Hugh Henderson
Message 29 of 34
antonkunipatz
Thank you, its working now. Is the issue likely to reoccur?
Message 30 of 34
henderh
Hi @antonkunipatz,
I appreciate the confirmation your jobs can process now.
We've taken steps to prevent this from occurring in the future.
Best regards,
Hugh Henderson
Message 31 of 34
axeldeblieck
Community Visitor
Community Visitor
Hello everyone, I am having the same issue with an education account with a bar stuck at 25%, can someone could help me?
Thanks in advance !
Message 32 of 34
henderh
Hi @axeldeblieck,
Thank you for providing the log files.
I found the submitted jobs on the back-end, and the latest job was not stuck. Instead, it ran for seven hours and failed during the meshing stage.
If you attach the f3d we can check the geometry to investigate why the mesh failed.
  • Use File > Export...
Hope this helps,
Hugh Henderson
Message 33 of 34
umarulug
Community Visitor
Community Visitor
I have the same problem, can you solve it. Mine is stuck at 24%
Message 34 of 34
henderh
Hi @umarulug,
Did the solve complete? I suspect the meshing / solving was taking a long time for your specific model when Job Status displayed 24% progress for an extended time.
If you're still having issues, please attach the f3d model and log files. I'd be happy to take a look.
  • File > Export... f3d file type
  • Help drop down > Support and Diagnostics > Diagnostic Log Files
Thank you,
Hugh Henderson
