Simulations has correct start point but machine does not start there.
genefeldmanaz
genefeldmanaz
I just got my Onefinity  X-50 Woodworker and I am using Fusion 360. Brand new to all this. I generated a simple square block of wood with a depressed hole in the center. When I run the simulation it works great. Start point is in the middle. When I run the program on my machine it starts machining at the homed corner of the work piece.
I homed the machine first then use the probe block to set the front left corner of the workpiece before running the program.
I’ve spent hours on videos and the web and have tried different changes. Always the same result.
Any help is greatly appreciated.
genefeldmanaz
Well I figured it out. Went back to a few videos and realized that my axis were located in the center, not the set point (front left corner0 on the workpiece.
I’m sure I’ll be back and this is a blast to play with.
