Simulation Status Bar Not 'loading'
Hi All
I will try to word the problem I am having as well as possible:
I'm playing around with static simulations and Design Optimizations a lot and that requires a lot of simulations (and re-meshing of changed objects). It seems to me that when ever I try to solve a new simulation- the "Solve status" window comes up but the status does not update (the blue bar does not fill up). I then restart Fusion and re-open the file and the results then appear or the status bars will show correctly.
Same with Meshing: I would re-mesh an object and the "Updating mesh" Window would appear- after a few minutes I would press "Cancel" and then the Mesh is updated.
Any advice for me or indication of what I'm doing wrong?
Kind regards
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
I am not too sure what might be going on. Do you mind creating a screencast documenting what you are seeing. That should help clear things up.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Hi @James.Youmatz
I've been trying the whole morning to re-produce the issue but with no success. I believe it MIGHT have something to do with internet issues I have been having. I will keep this thread on Ice until I can re-produce the issue.
Thank you for your quick response though!
Kind Regards
