Simple operation on rectangular pattern
Question from a newbie.
I want to fill the side of a wooden box with wood boards so I use Rectangular Pattern.
The amount of wood boards is calculated, depending on a Height parameter of the box, and a Width parameter of a single wood board.
Now I want to cut the top board.
I use the tool "modify" -> "split body" by using a plane.
The result is that every board is cut, which is not desirable of course.
Can you advice me on how to do this correctly?
Roeland
g-andresen
please share your design
File > export > save as f3d on local device > attach to next post
günther
File is attached
