Message 1 of 25
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm having a difficult time attaching a simple hinge to a cabinet where the cabinet dimensions are parameters that can change. (file attached). I built hinge components from a McMaster-Carr hinge and want to place at outside corner edge of cabinet. It's not clear how to select the points on the hinge and cabinet to put the hinge in the corner intersection. I read that one must create a sketch built using the parameter dimensions and align the hinge to that sketch. Also need a rigid joint to fix to the cabinet surfaces and maybe the door too.
Once done, how do I actuate the door without going to "drive"?
Watching tutorial videos it seems so simple...until I actually try it 😞
Thanks!
