Sign In failure
Sign In failure
Sign In failure
I've been having a problem since I first installed fusion 360 about a week ago. When I launch the application on my pc it gives me an error screen which says :
There was an error while logging in to Fusion 360.
Anyone with a solution please I would appreciate the help.
Here's a picture of the error: Screenshot (48).png
I would appreciate the help very much since I need to use the program for a class.
julia.paganucci
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Thanks for posting!
Have you gotten a chance to look through this support article? A lot of time this is due to a proxy, or firewall/antivirus. Can you please post your log files here if that article doesn't help?
Julia Paganucci
Technical Support Specialist
| Autodesk Knowledge Network | My Screencasts | Fusion 360 Webinars | Tips and Best Practices
Here are what I suppose is the application files: Screenshot (49).pngScreenshot (51).png
julia.paganucci
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Yes those are the files! Can you please attach the most recent one (should be at the bottom) in your reply? And can you also attach your web services file? (C:\Users\***\AppData\Local\Autodesk\WebServices ). Did you also happen to go through the article?
Thanks!
Julia Paganucci
Yes, I went through the files and neither the proxy nor the network was the issues to Fusion according to the aid given to me. Thanks for letting me know about the article.
Here are my most recent log file as well as my services file.
julia.paganucci
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Thank you for the logs! Various settings on the machine can cause the system time (although perhaps displayed correctly) to appear incorrect. This solution article shows how to verify this and sync the clock with internet time. Please follow those directions and let me know if this helps!
Julia Paganucci
