Shortcut Key toggle "Object Visibility" "All Work Features"
dlancev
Message 1 of 9
dlancev
On complex design with many sketches and work features, I like to see everything clearly. I am looking for a shortcut key to toggle visibility: "Object Visibility" >  "All Work Features".
There does not seem to be one and I do not think I can map one with the current implementation of "Change Keyboard Shortcut.." command.
Replies (8)
Message 2 of 9
FormStudio
Thanks for posting - I am also looking for this functionality. Having to go to the menu to switch on/off work feature visibility is not an efficient workflow, would much prefer a hotkey / shortcut to achieve this.
Cheers
Message 3 of 9
qcrispin
Observer
Observer
Totally agree there should be a keyboard shortcut for this.
Message 4 of 9
JDR_10x
Observer
Observer
Once I discovered the amazing convenience of this toggle, I immediately began using it CONSTANTLY.  If you haven't already, I highly suggest you try it as part of your work flow.  But alas, I too am sorry there is no keyboard shortcut for it.
Message 5 of 9
bentwookie
I use the toggle all the time as well. It's very hard to move components along their joints without the sketches turned off. And then I immediately forget that I've turned it all off and wonder where my sketches are 🙂 A keyboard binding would be soooo nice. (and easy to implement I'd think)
Message 6 of 9
anthony.esau
A keyboard shortcut to toggle "All Work Features" would be very helpful for me as well.
The add-in called AnyShortcut is a workaround for many other functions that don't have default built-in keyboard bindings, but it isn't compatible with "Object Visibility" > "All Work Features" in my testing.
Message 7 of 9
MoonshineSG
a shortcut for this would be extremely useful...
Message 8 of 9
stefan.mueller4Q8UZ
i just tried (apr 29th 2023) to put this function on a 3dconnexion button through their UI, but no success. They offer a range of fusion functions for user buttons within a dropdown, but unfortunately the toggle for 'all work features' is missing.
Message 9 of 9
Cami_Fracelli
i seem to have find work around with aliases and 3D connection mouse
1. Create aliases that you want to toggle:
2. Create a macro in 3D connection
Not thoroughly tested but seems to work.
NB : it's a toggle so if you manually toggle one of them they will "loose" sync.
For those that are not using 3D connexion : i quite sure it will be possible through AutoHotKey
Have a good day toggling 🙂
