Shift MMB doesn't orbit
Message 1 of 10
Shift+MMB stopped working on my desktop, works fine on my laptop...Preferences are set to Fusion, ???? please help
Replies (9)
Message 2 of 10
kate.raskauskas
Hi @Anonymous,
Oh no, I'm sorry to hear that! Can you please check to see what version of Fusion 360 you have (under Help > About) and let me know what type of laptop and what OS you have?
Kate Raskauskas
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tip and Best Practices | Troubleshooting
Message 3 of 10
kate.raskauskas
Also, what type of mouse are you using?
Kate Raskauskas
Message 4 of 10
Thanks for your reply,
fusion 2.0.3802
I'm using HP Z1 G2 workstation, with HP keyboard and mouse Keyboard Model
KG-0851
Mouse Microsoft 6.17600.16385
Message 5 of 10
kate.raskauskas
Hi @Anonymous,
Thanks for the info!
If you switch to another configuration, does the shift button work there? (the SolidWorks setup uses Shift+MMB to zoom and the Alias setup uses Shift+Alt+LMB, Shift+Alt+MMB, and Shift+Alt+RMB for pan, orbit, and zoom, respectively)
Kate Raskauskas
Message 6 of 10
I updated to windows10, uninstalled and reinstalled fusion, I can only pan
and orbit in Inventor mode,
Message 7 of 10
kate.raskauskas
Ok! Have you tried in SolidWorks or Alias mode as well, or just Inventor?
Kate Raskauskas
Message 8 of 10
yes, I've tried every configuration possible
Message 9 of 10
kate.raskauskas
Ok, in that case can you please double-check that the batteries in the keyboard aren't low, and if your system has energy settings for USB devices that the keyboard isn't set to an energy saving mode?
We generally see this issue happening with Macs or with a SpaceMouse-- after you've double checked the above, can you please upload your log files so I can take a look through them?
Kate Raskauskas
Message 10 of 10
kate.raskauskas
Also, what display settings and grid/snaps options do you have activated? For example, do you have the layout grid activated, what visual style are you using, etc?
Kate Raskauskas
