SheetMetal not able to make a box correctly - please help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, the long awaited Sheet metal functionality looks very cool Thank you sooo much for getting it published and released to the public
I do have an issue and not sure how to get it to work correctly Please see attached photo and .f3d file. the problem is that when making a simple box the corners are not generating correctly as i would expect for a sheet metal box to look like. in the corners it is cutting out a 0.60 size area at the root of the bend and i don't understand why. i have tried changing all the settings when making the flange but no use. tried the bend overrides but no help, if i put a value less than the radius (0.06) it just gets ignored, if i put 0 it gets an error i just cant get the two sides to come together as you would hope it would. Material is 0.060, 16gauge CRS
Thank you for any help in advance
Regards
Mitch
