Sheet metal: Trouble converting pipe "y" to 5/16" plate
Message 1 of 9
https://a360.co/3yaw5cU
I'm having trouble with a pipe "y". When I thicken the lower part of the "y" and then try to convert it i get this error message. " Can't calculate body thickness. Select the base face of a valid sheet metal body.  Any Guidence would be appreciated.
Thank You
Replies (8)
Message 2 of 9
ryan.bales
Autodesk Support
Autodesk Support
There are two reasons it normally would not convert:
  1. Non uniform material thickness
  2. Closed/self intersecting object
The main upper part of the body will convert, but it would never be able to unfold or create a flat pattern as its a closed object with no foldable surfaces or edges.
That being said, you need to do some surface modeling work to get the lower part to be a solid, so that it will convert to a solid first.
  1. First reverse normal on the bodies that are flipped the opposite way
  2. Second stitch all four surface bodies together
  3. Thicken the faces the correct direction
  4. use Solid combine to combine the bodies.
  5. Convert to sheet metal (just note again, this is not a 'valid' sheet metal object in fusion and next to nothing with sheet metal tools will work)
Ryan Bales
Fusion 360 Product Support
Message 3 of 9
ryan.bales
Autodesk Support
Autodesk Support
File attached/
Ryan Bales
Message 4 of 9
TheCADWhisperer
Are you interested in seeing the correct solution with 3 Flat Patterns and no unresolved issues highlighted in the Timeline?
Do you have a preference where you would like to see the Rips (seams), otherwise I will use shortest Rip solutions for each component.
Message 5 of 9
Yes that would be very helpful.
Message 6 of 9
TheCADWhisperer
I added a request for additional information about the desired Rip location to previous response.
Message 7 of 9
The shortest seams
Message 8 of 9
TheCADWhisperer
Here is my attempt.
Because it is not a true conic - I was not able to get it to convert to sheet metal in Fusion 360.
Message 9 of 9
TheCADWhisperer
I discovered that my Sweep did not result in a planar surface (required), but I am not confident that fixing that error would resolve the issue of obtaining a FlatPattern of the Lofted faces.  But that is where I would spend my time and effort.
