Sheet metal - flat pattern bug.
saso_grinaver
saso_grinaver
If you have for example this contour (circle in circle -picture under) sketched on front plane, and you just want flat pattern (dxf countour) = you get countour from top plane.
TheCADWhisperer
@saso_grinaver
I do not see a *.f3d file or a *.dxf file Attached here to illustrate the issue.
Start a New Sketch on the face of the part.
P for Project and select the Face (not an edge).
Finish Sketch.
Right click on the newly created sketch and Save As dxf.
Tip:  For something that simple you probably could have done the same from the original sketch.
saso_grinaver
Here is no problem create a dxf.
Problem is bug.
g-andresen
You only provide a top view, but nothing in 3d.
Please share the f3d file as @TheCADWhisperer has requested.
File > export > save as f3d on local drive > attach to post
günther
saso_grinaver
Model is sketched on FRONT PLANE !
If you now make a flatt patern, for exporting a dxf, u automaticly get on top plane (bug).
But if you for example make a square in midle of circle, you get the right selected view/plane !
You can test for yourself.
TheCADWhisperer
@saso_grinaver
Yes, attach your *.f3d and resulting *.dxf files here so that I can test for myself.
Do you have your Fusion set up so that Z axis is up or do you have set so that Z axis is Front?
