Shared public links fails with "Unauthorized Sorry. You don't have permission to access this page."
chazz
Message 1 of 17
chazz
All public links to all my projects and drawings fail with the below message.  I have tried multiple browsers and tried generating links from inside Fusion desktop and from the web project browser (the links are identical).  I have waited for "propagation" for several hours with no change.  Same results on laptop and iPhone.
There are numerous forum queries on this but no definitive solves.
Replies (16)
Message 2 of 17
HughesTooling
Do you have either a commercial or educational license?
Mark Hughes
Owner, Hughes Tooling
Message 3 of 17
chazz
Thanks @HughesTooling. To the extent that I understand it. I have a regular Teams commercial subscription (I am the only member of my team).
Message 4 of 17
chazz
I also have file sharing enabled per the below.
Message 5 of 17
chazz
I'm probably doing something wrong but I have gotten it to work reliably in the past.  And perhaps my beef here is that Fusion should not allow me to generate a link which it then denies access to without giving me some sort of warning.  It's embarrassing when sharing with clients.
Message 6 of 17
HughesTooling
OK, I just wanted to make sure you were not using a personal license which doesn't allow file share links.
Mark Hughes
Message 7 of 17
HughesTooling
@James.Youmatz Might be the best person to help.
Mark Hughes
Message 8 of 17
James.Youmatz
Autodesk Support
Autodesk Support
Hey guys,
Thanks for tagging me. @chazz dumb question but does the public link populate when you are in incognito mode in a browser? My thought here is, in incognito you won't be signed into any account. If it works this way, but for some reason won't load when you're logged in, something is strange.
Do you have an example share link you can post so I can test if I can access?
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 9 of 17
chazz
Thanks @James.Youmatz, using the below link as a test, I get the same failure in Chrome Incognito and Safari Private.  Here's the sample link: https://a360.co/4dKkyH3 (which resolves to https://chazzhacking.autodesk360.com/shares/public/SH512d4QTec90decfa6ef1dd484a549ffa9a )
Message 10 of 17
James.Youmatz
Autodesk Support
Autodesk Support
Yea I'm seeing the same with that link. Let me dig with the teams and see what might be happening.
James Youmatz
Message 11 of 17
Andy.Spivey
hi @chazz - the anonymous account used for accessing the public shares was flagged as disabled in the hub.
I marked it as active - links should be all set now!
Andy Spivey
SQA Engineer
Message 12 of 17
chazz
Thanks @Andy.Spivey. and sure enough, it works now!!  Could you explain that a little more broadly?  I don't understand the "anonymous account".  What account is that?
Message 13 of 17
Andy.Spivey
Sure @chazz - the account that controls the "anonymous" access for viewing the public share pages is the system / bot account.  You'll see it in teams as the account that sets up things like the Admin and Demo projects (System)
Andy Spivey
SQA Engineer
Message 14 of 17
chazz
Thank you.  I had no idea.  I still wish it would give me a warning of the issue rather than just bonking on the link.  But thank you.
Message 15 of 17
kankiWWSVD
I am having the same problem. I read this thread and tried to fix it but I can't find the anonymous account in the hub. Can anyone tell me how to fix it?
Message 16 of 17
k.fujiwaraDW548
Community Visitor
Community Visitor
I am the same person. I am having trouble sharing projects from this account. Can I fix this via the web?
Message 17 of 17
Andy.Spivey
hi @k.fujiwaraDW548 / @kankiWWSVD
My apologies for not seeing your post above on the thread (it was already marked resolved).  Saw it today - the issue from the original poster was the same on your hub as well and we have corrected it.
Again, my sincere apologies for not seeing the reply until now - things should be all set for your hub now.
-Andy
Andy Spivey
SQA Engineer
