Setting equal exterior distance between different size objects.
sullivan_ranch04
sullivan_ranch04
I want to start by saying I am not very familiar with Fusion 360 or 3D modeling as a whole. I primarily use this program to make my own Gridfinity storage units witch I then 3D print. Saying that a common time waster I fell like is setting the distance between holes where I want a socket to go. In the first screenshot you can see I simply set number to be the spacing between centers. But where I lose a lot of time is when I start having to calculate and set distance between two different size objects. Like the second screen shot shows. My solution right now is the copy/paste this function and enter the number manually. ((O1/2)+(O2/2))+3 This function gives me a 3mm spacing between the objects exterior. Is there a better way to do this?
jhackney1972
Please do not double post on the Fusion Forums.  Chose the one most fitting and only post once.  Your other post is here.
John Hackney, Retired
