Selection bug, latest version?
HughesTooling
Consultant Consultant
HughesTooling
In the past you could double click a body and it's component would be selected, then right click and select Isolate. With the latest version of Fusion 2602.0.71, if the mouse pointer is still over a face when you right click the face highlights so you can't select Isolate.
I still have a PC that has not been updated and right click while over a face leaves the component selected.
This is the old version of Fusion after the right click.
And this version 2602.0.71
EDIT. This is also a problem activating a component. In the past just double click a body, right click and select activate. Now you have to find a clear space on the screen with no faces before the right click.😖
Mark Hughes
Owner, Hughes Tooling
RajkumarIlanchelian
@HughesTooling We are aware of this and a fix should be coming shortly. A workaround for now is posted here
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
RajkumarIlanchelian
We released 2602.1.14 a few hours back that should address this issue.
Autodesk Fusion
Join Fusion Insider
