Select referencing joints
mac_ito
mac_ito
When I right click to find out the joints nothing is displayed in the browser, why?
Also, the seal icon appears in the view but does not happen when I try to edit it. Is this normal?
(view in My Videos)
mac_ito
I tried again, it seems that the problem is only present with components which are imported .step files
For other elements built with fusion it works
(view in My Videos)
TrippyLighting
That should not be happening!
You'll likely be asked to share the model(s)  (with an Autodesk Employee, not with me 😉 )
@Phil.E can you check this out?
mac_ito
👍🏻 I inserted the file in the first message
mac_ito
Still on the subject of joints, can someone explain to me why in my final assembly the joint icon appears although I have hidden them in their assembly?
In addition, I have no way of hiding them in the final assembly because the image is grayed out. is this normal?
(view in My Videos)
Phil.E
For the first question, you must first select the component that has the joint in order to select referencing joints.
Second question: I didn't see this in the model you had attached. How can I get into the situation where joint origins are visible, but the linked design browser tree shows them as not visible.
Phil Eichmiller
Software Engineer
Quality Assurance
