Select face to apply fillets to all joined edges?
Message 1 of 10
So I am new to Fusion 360 - I am a long time Solidworks user.  When doing fillets, in SW, you can select the face of a cube for instance and invoke the fillet command.  From there, SW would select all edges associated with that face.  This is one click as opposed to 4 individual 'edge' clicks.  Is there a similar capability in Fusion?
Accepted solutions (4)
Replies (9)
Message 2 of 10
jeff_strater
Not yet, but it is coming soon.  That exact UI will be supported in an upcoming release.
Jeff Strater
Engineering Director
Message 3 of 10
TheCADWhisperer
No.
Best you can do is Window select or Crossing Window select multiple edges.
Message 4 of 10
HughesTooling
What about Rule Fillet or am I missing something?
Mark
Mark Hughes
Owner, Hughes Tooling
Message 5 of 10
Hi Mark,
Sorry I am a newbie and am not familiar with that?  I've attached a screen shot showing a plate with multiple holes drilled in it.  I would like to select the one face and have each edge picked after that by the software.  Would "rule fillet" do this?
thx
Message 6 of 10
HughesTooling
Select the face then from the modify menu select Rule Fillet.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-D5CDA6FA-C019-4769-85D3-D4E8D3F283F5
Mark
Mark Hughes
Message 7 of 10
ok...so I love this option...one problem.  I don't see the choice...  In the Modify drop down, I only see "fillet".
Message 8 of 10
TheCADWhisperer
Did  you turn off Capture Design History?
If so, do you have a logical reason for that?
If you turn Capture Design History back on - do you then see Rule Fillet?
Message 9 of 10
interesting...
I have no recollection of willfully doing that.  I did import this as a .STEP file and this file is really horrible with ton's of disjointed surfaces.
Me being a complete newbie - I may have inadvertently clicked that but I don't think so.  Anyway - that seemed to fix it.  thx for the help.
Paul
Message 10 of 10
HughesTooling
Imported files default to direct modeling mode.
Mark Hughes
