Section views on separate sheet
batchelder_jimmy
batchelder_jimmy
I have a large flat part I am making drawings for. Both the top and bottom views require their own sheets. I need a section view on a sheet by itself but I cannot figure out how to move a view from one sheet to another. Is this possible?
HughesTooling
Insert a base view off the sheet, add the section and drag the view onto the sheet. If you just export as a PDF all you'll see is what's on the sheet. If you save as a DWG the base view will show as well.
Mark
Mark Hughes
Owner, Hughes Tooling
batchelder_jimmy
That will work for me I think but I’ll lose the section line.
HughesTooling
Do you mean on one of the other sheets? You could add the section on the other sheet and just move the view off the sheet, then edit the text on the section view to match.
Mark
Mark Hughes
