Thanks for the details.
There are zero known crashes related to the default add-ins. I was thinking it might be one of the few that need updating, but that's clearly not the case.
Looking at your crashes (thanks for sending the reports) you tend to crash in the same areas over and over, doing the same things that crash repeatedly. That explains a lot of your experience of "crashing constantly".
For instance, you crashed several times in a row trying to drive a revolute joint. If it crashes the first time, might be "random", but after two times doing the same steps and getting the same result, it's time for different action.
First, if you can share the model, post a link to it here and give instructions. "Open model, drive revolute joint X, Fusion will crash". That kind of report helps me get a reproducible case for the developers who can debug it. If you can't share a public link for the model, send me a PM. In this way you can help yourself and all other customers in the same situation by helping find and fix these problems.
Regarding the revolute joint, did you try deleting it and replacing it? Just curious if you found a workaround after so many attempts to drive the joint.
I also see a bunch of recent force quit crashes. Those can be tricky. Sometimes Fusion is doing perfectly expected things while the beach ball is showing, such as computing the design, or opening a design. Please give it extra time if you find yourself repeating the same actions over and over and getting the same beachball freeze. If you think a design will not open at all, share the public link. Many times these can be downloaded and debugged.
All this is said to say thanks for paying close attention and for your help. Let's figure out what's going on with your crashes before you feel like it's crashing "all the time" over just a couple issues. The list you provided is literally the list of #1 workflows for all Fusion customers. If any percentage of people using Fusion crashed as repeatedly as you do in those workflows we would have alarms going off over here.
Glad you took the time to list it all out, now let's narrow it down by exploiting the obviously reproducible cases you seem to find.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
