Section Analysis not maintained while performing any operations on parts/assemblies
colin.andersonT6LBZ
Observer Observer
colin.andersonT6LBZ
Observer
Observer
Hi there,
Looking for help with a really damaging bug to my workflow using the section analysis tool. Like others I've had issues with section analysis not behaving properly (be it being flipped, disappearing immediately amongst a number of other random failures). .
Most egregious bugs as follows:
The analysis not showing after being set despite viability being enabled (I have to double click the analysis in particular in the side tree to edit it to show it again at all). This is incredibly frustrating and happens consistently.
Even more frustrating is now analysis will disable as soon as I use any operation at all. A .5mm offset? Turns itself off. Small chamfer? turns itself off. It really doesn't seem to matter what the operation is, it cancels the section analysis by doing anything in the solid environment (have not tested in other environments). This makes key assemblies in our work almost impossible to work with. This never use to occur and now it happens every time I use the section analysis tool.
Has anyone had similar behaviors and is there a solution on the horizon?? This is having a significant negative impact on our development. Praying this is fixed soon!
Cheers,
P-BvanWyk
Good day @colin.andersonT6LBZ,
Please extract and send the Fusion 360 file you are having trouble with.
I Would like to do a couple of tests on it.
Please click on Accept Solution to help other community members solve their issues.
Also, consider giving a Like to the comments that you feel added value.
Kind regards,
Pieter-Ben van Wyk
