Scroll wheel no longer scrolls lists/dialogs
peter_meilstrup
peter_meilstrup
Ever since a couple updates ago my mouse scroll wheel stopped working in Fusion lists and dialogs. Note I'm not talking about scroll-to-zoom. I can scroll to zoom in/out the 3d view just fine. What isn't working is scrolling in the data panel, in the Change Parameters dialog, the Open File dialog, or almost anywhere else there is a scroll bar in the UI. (the timeline scrolls okay though.) The scroll wheel works fine in other apps. Is anyone else experiencing this?
dsouzasujay
Hi @peter_meilstrup ,
Thanks for reporting, I understand how inconvenient it is when the scroll wheel stops responding
Let’s try a few checks and steps to narrow down the cause:
  • Check Fusion version
    • Go to Help --> About and confirm the Fusion build version you’re currently using.
  • Reset UI
    • Try resetting the UI layout:
      Help --> Troubleshooting --> Reset Fusion Default Settings.
      Relaunch Fusion after that and check if scrolling works again.
  • Verify mouse and system input settings
    • Ensure your mouse driver or input software (like Logitech, hp, etc.) is up to date.
    • If you’re using any custom scrolling or smooth-scroll features, try disabling them temporarily.
    • Test with another mouse, if possible, to rule out hardware or driver-level behavior.
Please let us know the status after you’ve checked
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
