scissor problem
scissor problem
hans2taverne
scissor problem
hans2taverne
Hi there,
I'm trying to design a scissor operated vacuum gripper system and I'v troubles to keep the vacuum grippers in a strait line. Whatever I do gripper 2 and 4 keeps turning istead of moving in a linear direction like gripper 1 (gripper 3 is fixed)
 I'm working with fusion 360 for only 4 weeks now or so maybe I need somewhat more excercise but I checked the internet regularly and I'can't find a solution.
I know fusion 360 has a found a lot of errors in my design but I don't believe that's the problem.
Can anyone help me ?
Thanks in advance,
Hans Taverne
innovatenate
Autodesk Support
Autodesk Support
The timeline was pretty bad off in this design. I decided to rebuild the assembly completely rather than try to fix what was there (it was faster for me to do it this way). I utilized X-References to help me rebuild the assembly faster and reduce the amount of Joints I would need to create.
Here's a demo of me playing with the results.
There's a lot of bad practices I noted in the original design.
-cross-component geometry projection
-sketch on the faces of other components when editing a different component
-lots of unnecessary capture positions
-not utilizing instances of components (copy and paste a component (not a body)
-yellow and red warning indicate problems in the timeline - these should be fixed as they appear.
Here's some items to consider.
Use RULE #1
This means if you want to create a new component try using the following guidelines.
  • Create a New component
  • Activate that component
  • Use the Isolate command to hide all the other components in a design
  • Sketch on the root origin planes of that component
  • Try to avoid projecting geometry external to that component (unless absolutely necessary - sometimes it is)
  • Avoid sketching on the surfaces of other components
When assembling, keep in mind that Fusion has a very flat or open structure. Ground only ground the component to the parent's origin. If you're trying to ground something in an assembly, try applying a Rigid As-Build Joint between that component and the root origin in the design.
Try to use sub-assemblies or reuse components whenever possible. It looks like you have the same component reused multiple time. However, because of the way you went about creating these components, they were separate components. You can copy and paste to make a new instance of the component. You'll see instance number after the colon (:) in the component's name in the browser.
I would recommend taking advantage of instanced components when the underlying body geometry is exactly the same between the components.
The only time you need to make a new component, is when the geometry will be different.
Here is some good learning material that may help to get you started.
I've also attached a sample model you can upload in the Data Panel and explore.
I hope that helps!
Nathan Chandler
Principal Specialist
hans2taverne
Nathan,
Thank you very much for your reply, I know I still have to learn a lot about Fusion 360 as I started only a few month ago with 123D design and since 4 weeks with Fusion 360.
Before that I only worked in 2D systems.
I'll study the material you send me and hope that I'm able to improve my skills.
Thanks again,
regards,
Hans Taverne
