Same designs on different computer?
angus_alc
angus_alc
Unfortunately, the computer that I have Fusion installed on broke, and I'm wondering that if I was to install Fusion on a different computer and log in with my account, would all my designs be there? Or do I need to export the .f3d files and send them to the other computer? Help would be appreciated.
seth.madore
Unless you are in the habit of exporting your files and working offline, all of your designs are going to be accessible from any computer that you log into, provided you use the exact same login credentials as you have been with your (now dead) computer
Seth Madore
angus_alc
Thank you! I do not ever work offline, so that should work.
g-andresen
However, you can only start Fusion on one computer.
If Fusion is still active on another system, you can close this instance when starting from the second system.
günther
