Right mouse not call function (Extrude, Filet, Chamfer ...)
s.ciunczyk
s.ciunczyk
I faced strange behaviour recently. When I try to call any function with right mouse click - extrude from profile, some operations on edges like chamfer, filet - any other operation the menu appears but I left-clicking on any function just closes menu without any action, This same from keyboard - right menu button - context menu then arrow keys to select function and enter works fine. I can live with this but is a little annoying.
PC: Microsoft Surface Book 2 10"
System: Windows 10 (19042)
Mouse: Microsoft Sculpt Mouse BT
Fusion360: 2.0.10032
I have no idea what to do ?
mohammed.aliTDPXK
Hello @s.ciunczyk ,
I tried reproducing the issue you are facing but I did not get the issue.
Can you please add a quick screencast for the issue you are facing?
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
mohammed.aliTDPXK
Hello @s.ciunczyk ,
I am on MacBook Pro and I am unable to reproduce the issue you are facing.
This may be related to the mouse you are using, let me check with the team and get back to you.
For now the workaround I would recommend you is to just
--> Click on chamfer, fillet,extrude etc form the ribbon bar first
--> And then add to your model accordingly.
Let me know if this helps. Do like the post and accept as solution if this answers your query.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
s.ciunczyk
Just FYI - I' using this mouse and laptop for last three year. The problem is new two -three weeks.
Also verified with two other mouses - same problem. My suspicions go to selection priorities/filters
s.ciunczyk
Anyway @mohammed.aliTDPXK please check with the team and let me know.
