ribs feature in multibody part does not work
MoshiurRashid
Thank you for posting. It would be good if you demonstrate the issue with more descriptiona,  provide us photos and also your f3d file.
(File> Export> f3d)
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
I may be using this feature for what it was not intended. My part is made of many bodies including the ribs. Perhaps a different approach is required. Oddly the geometry i am attempting to create via the rib feature are called ribs in the physical apparatus (boat) hence the expectations of this feature:)
MoshiurRashid
Hi
Why dont you create it as another body and "combine" it? Please have a try.
Moshiur Rashid
ACP | CSWE
LINKEDIN | FACEBOOK
the design objective is to have a multibody part
ribs feature in Onshape works elegantly! normal or parallel to sketch plane, multibody, merge or not merge
TheCADWhisperer
File>Export and Attach *.f3d file here.
