Revolving frustration
heinrichludike
heinrichludike
I am busy with an interesting little project and the revolve function is perfect on paper but it is not working. For some reason, I can wrap around X and Z, but it refuses to highlight the Y-axis. This is where I need the part to revolve around.
Very strange that the other 2 work perfectly but the one I need is refusing over and over. I disabled all the sketches and everything so only the 3-axis are available but for the life of me, it is just not letting me revolve around that axis?
I have closed 360 and reopened it. Same issue. I hit a brick wall any help would be appreciated.
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
günther
wmhazzard
A revolve of a sketch to an axis perpendicular to a plane is not possible, it would give a 2d body so is not possible. Hence, only two axis can be selected.
heinrichludike
Thank you, I ended up taking another route which seems to be working. Though this makes sense.
