Resizing UI crashes fusion 360
holycause
holycause
Every time I try to resize the UI, like maximizing it, it crashes Fusion360
This started yesterday, and I can't work with such a small UI.
Thank you in advance.
some info regarding the crash:
Date/Time: 2022-06-02 19:19:37 +12:00
Application: Fusion360.exe
Error: Access violation - code c0000005 (first/second chance not available)
Crashed Module Name: libGLESv2.dll
Exception Address: 0x00007ffc5d3aeedb
Exception Code: c0000005
Exception Flags: 0
Exception Parameters: 0, 0
holycause
adding my computer specs
GPU: Geforce RTX 3090
holycause
anyone having an idea, it's really frustrating to not be able to work.
I tried to re-install it multiple times and made sure that all the drivers are up to date.
nothing works
holycause
I found a solution.
I replaced the libGLESv2.dll file from another app I had installed ( in this case MS Teams) and that fixed the issue.
