Resizing Fusion 360 application on windows 7
When I start Fusion 360 on my window 7 PC, the application window spill out of active display region. How to resize this application? I tried the usual go to corner and drag the
corner to re-size. Did not seem to work. Tried "Sizer" freeware did not work. Tried changing the screen resolution.. no dice.
Phil.E
Have you tried dragging the other corners of the application frame?
Phil Eichmiller
Software Engineer
Quality Assurance
First , the application is larger that the screen so I cannot access the bottom corners.
If I move the application window right  and down the left top corner is available.
No matter how much I try to drag this corner it does not re-size.
Not sure if it is the windows 7 machine I am using or if it is just this app.
I tried with several other apps, such as eagle cad. I am easily able to re-size the
application window.
The version I am using is in the screen snap below.
Marco.Takx
Hi @Anonymous,
In this link you find the text below.
Important Notice: Windows 7 Compatibility
As we continue to develop Fusion 360, not only are we improving existing functionality as well as implementing new features into the software, we’re also maintaining support for a number of different operating system versions (for macOS as well as Windows). This means testing for bugs, developing fixes for them, as well as releasing important updates.
Back in January 2020, we announced that we are ending Windows 7 support. For those of you still running Windows 7, you can still run Fusion 360 but we will no longer be supporting it with testing and fixes. We recommend that you upgrade to a new version of Windows to get the most out of Fusion 360. Check out the Microsoft Windows 7 page for things you can do.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
