resizing copied sketch elements causes pretzle
aernan
aernan
I'm a newb and I'm making some kind of basic mistake I can't figure out. When I dimension some copied sketch elements they invert and become pretzles. How do I avoid that?
https://a360.co/30qAgSJ
davebYYPCU
Add detail,
constrain it as desired,
dimension it, when fully constrained
add more articles.
Might help....
g-andresen
1. replace these 2 radii with only 1
2. remove some restrictions where appropriate
günther
aernan
That is totally the root cause. Thanks. I see a tiny line segment which I assumed would work. I'm redrawing all those radius on all the sketches now to fix that issue.
aernan
After fixing/adjusting the next sketch element the problem repeated. I think the use of a radius messes up the parametric relationship. I will fix this design entirely then make a stand alone demo and try to report it as a bug.
g-andresen
Note: It is not a good idea to create 2 radii in such a case.
Try it like I show it in the GIF.
> Start a normal line, drag it to the side and connect it to the opposite point
günther
aernan
Thanks for pointing that out a second time. I will use that next time.
The original beam has a flat landing so that's what I modeled. At this point the radius has caused such trouble I will instead just leave the corners square.
I might make another demo copy of this problem to see if there is a way to do it with the simple models I have made.
