Resize text
Resize text
Resize text
I have a box that is 7”x32.5” and I’m using artifact element text and I need my text to fill that whole dimension but the text only gets longer length wise when I try to resize. How do I get the text to move width wise instead?
leowarren34
Hi @Anonymous,
If you mean resize by changing the X Y Scale independently then create the text and create it into a body and then use the scale tool under modify, select nonuniform as the scale type (see image below). If you just want to increase the size then double click the text so the dialogue box appears.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
