Replace Component feature not appearing on context menu
dovroar
Observer Observer
dovroar
Observer
Observer
I am on the latest version of Fusion 360 and the "Replace Component" command has completely disappeared from the context menu. I have tried right-clicking with component priority, and the result is the same.
lanparty233
@dovroar  I see you do not have a active timeline in your model, that makes it hard to go back and fix or modify things, without a timeline.  To turn it on: Link here
Another thing I would do is divide your design into sections also put your parts in there corresponding section as its own component tree, example: back wheel - bearings / wheel / spokes/ cog/ and so on all in the one file, makes things easier to find.
jeff_strater
It looks like the design in the screen capture you shared is composed of only "local" components.  Meaning: defined within a single design, as opposed to "linked" or "external" designs, where that component is defined in a different design altogether, then inserted using Insert Into Current Design.
Replace Component is only available for external/linked components:
Screenshot 2023-07-15 at 7.44.36 AM.pngScreenshot 2023-07-15 at 7.44.15 AM.png
Jeff Strater
Engineering Director
