[REP] CAM Calculation error on specific case
CAMXPRESS
CAMXPRESS
Dear Support Team,
We have found a reproducible error message in the CAM module (see pic: Error_03).
To reproduce it do the following:
- Create a simple radiused corner cube (see pic: Error_01)  OR open the attached model.
- Create a 3D Contur operation with the following parameters:
   - Select two Avoid surfaces that are vertical, and the radius surface ends there. (See pic: Error_01)
   - Disable the Leads in/out.
   - Select Ramp to Plunge
>> Calculate the operation
   OR
>> Regenerate the operation at the attached model with a new Avoid surfaces tolerances (to force
      regenerate the triangle model by the kernel. Sometimes it need to change it twice.)
Hints:  I think the problem comes that the kernel run error because of the limits of the operation (by the Avoid
          surfaces) is located in the same position where the operation cutting moves start (without any leads).
Joe
CAMXPRESS
Here is the model.
CAMXPRESS
Any news about that bug?
robert.filiks
Hi Joe,
Thanks for posting. I was not able to replicate the behaviour using the latest version of Fusion 360 2.0.10564. Did you submit an error report by a chance?
Robert Filiks
Software QA Engineer
My screencasts | Advanced Manufacturing | Tips and Best Practices
CAMXPRESS
Hello Robert,
Thank you for your answer. I have confirmed that this bug is not present in the latest (v2.0.10564) version.
Thank you! Regards,
Joe
