Rendering Ground Plane Issues
polygrinder
polygrinder
I have a scene I have set up. All of my bodies are sitting on the ground plane in the Design workspace.
When I go to the Render workspace and do an "In-Canvas" render in my viewport all works fine. The items sit on the ground plane and cast shadows and reflections correctly on the ground. However, as soon as I submit the render to my "Local Renderer", so I can produce a larger render, the objects float in the air.
Does anyone have any hints as to why the ground plane shifts in this manner?
Any help would be appreciated.
TrippyLighting
Can you share the .f3d file? Might be a bug.
polygrinder
Here is the Fusion file.
polygrinder
I figured out the issue. I imported a mesh into the scene. The mesh is the issue. If I delete the mesh then the scene renders fine. Fusion must have an issue with imported meshes.
