Rendering gallery not showing up?
不适用
6,325 次查看
5 条回复
1 条消息(共 6 条)
不适用
Hello anyone and everyone. Ever have the Rendering gallery not show up? It shows up in my other projects but not my most recent one. When I choose to due a local render it continues but no images show up at bottom just a message (Render Gallery not found!) Tried to relaunch Fusion too. Let me know if you can help, thanks!
0 个赞
6,326 次查看
5 条回复
回复 (5)
2 条消息(共 6 条)
innovatenate
Autodesk Support
Autodesk Support
To get the Rendering Gallery images to appear you need to save the design and wait a while for the automatic renderings to show up or you need to perform a cloud render.
Check out this blog post for details and let me know if it helps.
http://www.autodesk.com/products/fusion-360/blog/render-in-the-cloud-from-fusion-360/
Nathan Chandler
Principal Specialist
3 条消息(共 6 条)
不适用
Not sure why it took sooo long to load up. I worked on the design for most part of the day, and did close the program down and started it up again. Hmm. But in the end came back later and bingo! They were all there.  Hmmm.
4 条消息(共 6 条)
t2Fi
That is happening to me too.  It normally is quite fast.
0 个赞
5 条消息(共 6 条)
stephenroyce
I'm getting this now, happened after the update.
Using MacOs - 360 version - 2.0.4262
0 个赞
6 条消息(共 6 条)
mehmetdogankaragoz25
Observer
Observer
Please try this.
0 个赞
