Rendering failure
Rendering failure
Rendering failure
What the heck is going on here??? The in-canvas is what I want, the online is what I got!Color1.jpgColor1-fail.jpg
TrippyLighting
Based on many user reports of this behavior it seems that cloud rendering assemblies was broken with he last update.
lucasliraAU
Hello
This is still a permanent problem for some cases within the 360 fusion, I have not yet found elements for a definite explanation.
I would indicate for this case to work with local renderings so you can get a result.
I worked on this case previously you can follow more about it here:
https://forums.autodesk.com/t5/fusion-360-design-validate/render-moving-parts/m-p/7953378#M156705
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
